I used my "A" drive (3.5 floppy) for the first time and now when I shut down my computer, it tries to access the "A" drive. It didn't do this before, and it's a little annoying. Any help would be appreciated.
YOU'RE anti virus software is scanning it most likely.
You can turn it off thru the settings in the app -
http://www.google.com/search?hl=en&q=stop+accessing+floppy+drive < google is your friend!
Try these tips:
http://www.annoyances.org/exec/show/article07-037
JSB -
you could also shut it off in bios so your computer doesnt even see it
PhenII 955@3.74 - GA-790XTA-UD4 AM3 - 2x4 Corsair Vengeance@1600 - Radeon 5770 - Corsair 550VX - OCZ Agility 3 90GB WD BLACK 1TB - LiteOn 24x - Win 8 Preview - Logi G110+G500 -
I think it's your OS checking to see if there's a non-system disk in the drive before booting since most BIOS set first boot as A drive. Even changing your boot order in BIOS doesn't fix this IIRC. All it does is growl quick before shutdown, right? Nothing to worry about really.
FB-DIMM are the real cause of global warming -
Thanks to all that replied
Originally Posted by rallynavvie
Originally Posted by JSBThanks for the links, I'll look them over to see if any of their solutions work for me.
Originally Posted by 808smokey
Floppy Drive Not Recognised
By spliffy in forum ComputerReplies: 38Last Post: 26th May 2010, 02:45 -
Setup cannot read floppy drive
By DarrellS in forum ComputerReplies: 11Last Post: 24th Mar 2010, 03:31 -
How to prevent limited user from accessing 2nd drive?
By alegator in forum ComputerReplies: 4Last Post: 20th Oct 2009, 21:43 -
What can I replace a Mitsumi DD floppy drive with?
By piano632 in forum ComputerReplies: 8Last Post: 19th Dec 2008, 08:00 -
Why does Login Box come up when accessing shared Drive?
By presto in forum ComputerReplies: 3Last Post: 5th Sep 2007, 02:52
