Title says most of it, I downloaded a concert which seems to be 1 hour 10 minutes long, but when I open it and add it to any DVD author program, it comes up as 3 minutes 50 seconds long, this makes it pretty much impossible for me to browse through the video properly so I can add chapters, and since im adding another video to the same disc, I dont know if it will fit or anything like that. So my question is this, is there any way to fix this kind of problem? I've tried converting the video to another type of file (AVI-MPEG) but the audio is completely gone (on the converted file) making it even more useless... So any ideas? Thanks in advance, very cool site.
Yeah, the original video is a mpeg file, so im gonna give that solution a try. Thanks.
Alright, so new problem came up. I noticed that the program only allows mpeg-2 files. I guess the video im trying to fix is not mpeg-2 since I got a message that read "Error, you're trying to restream a multiplexed file. Demultiplex the video-stream first".
So, how do I pull off that second stunt?
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
SVHSc -> DV -> PC but i lose any date/time info
By jomk in forum Capturing and VCRReplies: 3Last Post: 16th May 2010, 06:03 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 05:07 -
Date/time info in video from Sony HD MPEG2 camcorder
By huykin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 27th Jul 2009, 13:50 -
Time and date info on High def video?
By David97 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 14th Mar 2008, 07:44
