Out of the blue this happened. what up?
InnerException:
StackTrace: at CodeLock._Secure.Authenticate(String pass)
at AxCodeLock.AxSecure.Authenticate(String pass)
at x3284ccece41ee22b.x210ff09a2516b1a7.x41f470203acc6 a6e()
at x3284ccece41ee22b.x210ff09a2516b1a7.x0507e45eec4e9 097(Object xe0292b9ed559da7d, EventArgs xfbf34718e704c6bc)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.ThreadContext.RunMessageLoopI nner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.ThreadContext.RunMessageLoop( Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at x3284ccece41ee22b.x210ff09a2516b1a7.xc447809891322 395(String[] xce8d8c7e3c2c2426)
Reinstallation has solved this in the past? Is this RC4?
RC2 I see that RC 4 is out I'll install that to see if it fixes my issue, thanxOriginally Posted by ChrissyBoy
Uninstalled previous version , Installed RC4 works like a champ. Time to play with it now. Thanx ChrissyboyOriginally Posted by snagged
SVCD2DVD Error when encoding menu??
By gsmb in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 23rd Feb 2011, 14:44 -
Error when launching VOB2MPG 3 PRO in Vista Ultimate 64bit
By ghostwulf in forum SVCD2DVD & VOB2MPGReplies: 13Last Post: 20th Mar 2009, 06:28 -
Error on Startup SVCD2DVD 2.5
By jenevans33 in forum Newbie / General discussionsReplies: 1Last Post: 10th Feb 2008, 05:05 -
Error reports in SVCD2DVD
By deoldeprinter in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th Nov 2007, 22:03 -
svcd2dvd error urgent request
By dvds2u in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 10th May 2007, 10:22
