I am using Dlink USB Video Capture device, is there any very good video capture device for analog camcorders to make VCD and SVCD
This is not an answer, but a question for you. I have been researching the Dlink device you speak of to determine if I should buy it, how has it worked for you? Does it capture a fairly good quality of video?
Sorry, can't tell you about other cards, I have no idea. -
I suggest the Sony DVMC-DA2. It hooks up to a firewire card in your PC and produces execellent captures. I just picked one up for $285. Worth every penny.
the dvmc may be ok, but sony's website is still bullshit.
it doesnt' tell you at all what format the dvmc saves to your hard drive. is it another bogus sony-only format or is it standard?
this thing looks great if it does mpeg2!
THIS IS HARDCORE
PS3, HDMI Splitter, Video Capture Device or Card, Ambilight, ADVICE!
By NexusSIX1976 in forum Capturing and VCRReplies: 5Last Post: 16th Oct 2011, 20:38 -
Need a recommendation on a new capture card/device
By MJDore in forum Capturing and VCRReplies: 1Last Post: 14th Oct 2011, 15:56 -
Do I need a firewire card to capture video from my miniDV device?
By MPTESE in forum Capturing and VCRReplies: 8Last Post: 16th Mar 2008, 08:55 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 04:31 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 17:15
