  1. i have a folder that has 20 TDA files that i want to transfer to dvd but when i try to open them i keep getting an error message. i have also tried to open using win rar but keep getting a pop up saying next volume required
    Remember to break long term aims into short term projects
    Jun 2004
    USA
    What is the name of the file? TDA, I assume you are talking about TMPGEnc DVD Author?
    If that is what you are talking about then the only file TDA puts out is a Volume 1 folder that has a video_ts folder and a audio_ts folder. If this
    what you have then all you need to do find a program, such as Nero, and burn it to DVD.
    bits
  3. The TDA files are in a folder i downloaded. when i try to open the TDA files the errrors occur
  4. "tda" is most likely the release group.....
    Or a palm file.
  5. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    ...or you haven't disabled the silliestdefaultever "hide extension of known file types" setting.
    /Mats
  6. Sorted. opened win rar and highlighted files 1-20, right clicked and extracted files. then used ultra iso to burn . ot worked.
    thanks for avice.
