I have a really short [about 4 min.] video piece I want to export out to MPEG2 [from FCP4] at the highest possible quality level.
At first, I used FCP's built-in MPEG2 encoder and set it to One Pass VBR [6.5 / 7.5, Motion detection: Best] and the results are only decent. It looks pretty good on an average TV, but, of course, it looks quite a bit worse on a computer monitor.
I tried Compressor next [60 min. High Qaulity encode setting], but I have yet to test this version out. I'm not very hopeful that it will look better on a computer.
The real problem is the interlacing... [Again, this is only noticeable on a computer monitor, of course.] How can I eliminate the interlacing and still retain a high quality MPEG2 encoding?
I just downloaded BitVice, and there are built-in options for de-interlacing. Should I be using the de-interlacing filter within FCP itself BEFORE I export, or should the de-interlacing be part of the actual encoding process?
Teach me...
Doesn't Mac have the equivalent of a sophisticated deinterlacing MPeg viewer like Cyberlink's PowerDVD for the PC?
http://www.gocyberlink.com/multi/products/product_main.jsp?ProdId=1&lang=enu
For TV & HDTV display, keep it interlaced. Progressive deinterlacing is done best in a quality DVD player hardware deinterlacer. Both interlace and progressive outputs are provided by the DVD player.
If you goal is computer display only, then a software deinterlacer should be used, or you could encode a separate deinterlaced MPeg2 optimised for RGB, more linear gamma, progressive computer display. -
Isn't iDVD also a player?
high quality mpeg-2 encoding
By deadrats in forum Video ConversionReplies: 202Last Post: 19th Jun 2012, 18:58 -
High Quality Encoding AVI -> MPEG2
By vl0001 in forum MacReplies: 2Last Post: 21st Jan 2012, 09:40 -
need encoding tips for better quality PS3-friendly MP4
By spicediver10191 in forum Video ConversionReplies: 6Last Post: 13th Mar 2011, 06:48 -
h264 and xvid encoding for: near-lossless and high quality ?
By vhelp in forum Video ConversionReplies: 10Last Post: 14th Sep 2008, 16:31 -
Encoding RM to AVI (high Quality)
By hzgg2 in forum Video ConversionReplies: 2Last Post: 22nd Apr 2008, 15:11
