I have a MOV file which has four audio streams. I can switch between the streams in Windows Media Player by PLAY > Audio and Language Tracks > Track 1,2,3,4
I am trying to convert this MOV to DVD compliant.
I have converted the video using MainConcept MPEG Encoder perfectly, however I am having trouble with the audio.
If I open the file in MainConcept MPEG Encoder, it will crash every time it tries to strat converting the audio. I have tried VirtualDub, VirtualDubMOD and NanDub to try demuxing the audio stream, however they wont even open the file; so how can I convert this MOV audio to DVD audio....
you need quicktime pro.
This converts the quicktime you have installed so it is now able to transcode and export
Opeen in Quicktime
FILE>EXPORT...mov to WAV
reapeat 4x with each seperate track hightlighted and you will have it! -
I got Quicktime Pro and extracted the audio stream using this. Thanks dcsos. Converts fine now in MainConcept
MOV with 25 separate streams.
By sikm in forum Software PlayingReplies: 2Last Post: 14th Oct 2011, 01:52 -
Dual audio streams in an AVI file
By edwardcr in forum Newbie / General discussionsReplies: 3Last Post: 19th Dec 2010, 08:33 -
Advice on how to downgrade the audio bitrate of a MOV file with AC-3 audio.
By InsanelyOne in forum MacReplies: 15Last Post: 13th May 2008, 22:40 -
Video but no audio in MOV file
By alegator in forum AudioReplies: 3Last Post: 18th Jan 2008, 16:43 -
Is it possible to split the Audio and Video from a Quicktime .mov file.
By StuartB4 in forum Video ConversionReplies: 6Last Post: 12th Jan 2008, 21:02
