can codec_sniper make your system unstable? i think i might have deleted something. is there away to check my system to see if i have deleted something (XP)? alot of my programs are crashing
use the repair function of xp
To manually invoke the system file checker, be sure you have administrative access then go to the command prompt and type:
sfc /scannow
The system will immediately begin to check all the current system files and restore the cached approved copies. You may be asked to insert the Windows CD as well during the restore.
Clue: Keep in mind that after you perform a system file restore you should install the newest service pack so you are running the most current, Microsoft approved system files.
For you XP users, SFC should be used as a last resort. If you have been creating system restore points, first roll back to your latest restore point and see if that fixes your problem."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
the service pack thing is optional - i never have installed sp2 yet
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
