  1. Member pchan's Avatar
    Mar 2003
    Singapore
    Hi All,
    I would like to convert some rmvb clips to VCD. Anybody try the Real Alternative 1.30 codec ? Will edit in Premiere and frameserve to TMPGEnc.
    Any comment is very much appreciated.
  2. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    I only know this way to convert rm to avi/mpeg
    https://www.videohelp.com/rmto.htm
    It works with Real Alternative
    La Linea by Osvaldo Cavandoli
  3. Handling RealMedia with VirtualDubMod
    https://www.videohelp.com/forum/viewtopic.php?t=231192
    Frameserving from VirtualDubMod to TMPGEnc should be no problem. But if you want to frameserve to Prmiere I'd probably use VFAPI Reader.
    Dec 2004
    Australia
    You could probably use makeAVIS, but for premiere you might be better off re-encoding to avi first.
