I have several small (750meg) MPeg's which I would like to put on Dvd's. Want know if its possible to put more than 1 Video_TS folder on 1 DVD and how.
Or the best way to go about fitting more than 1 on a DVD and it being playable on standalone ?
1) No: 1 DVD, 1 VIDEO_TS folder.
2) You just go: "Add title" or whatever your particular authoring app calls it.
/Mats -
Only one VIDEO_TS folder per DVD but you can add several small movies it this folder. I like using TMPGenc DVD Author for doing this as it will do the work for you. Look in the tool section to find it. You can download a trial version to see if it will work for you.
Thanks guy's, I have TEMPgenc DVD Author. I am as you can see a newbie and did not have any idea how to start. Will follow through from here.
Need to put a bunch of movie scenes together
By neworldman in forum EditingReplies: 2Last Post: 1st Oct 2011, 22:55 -
Wanted to put 4 CD's on one DVD
By happydog500 in forum AudioReplies: 2Last Post: 16th Sep 2011, 20:15 -
How to put 640x480 video in 1280x720 frame in Sony Vegas Movie Studio?
By vid83 in forum EditingReplies: 6Last Post: 10th Feb 2011, 23:47 -
Help with Ripping audio from a VCD (2 discs) to put 1 DVD for a movie.
By shuya_nanahara in forum Newbie / General discussionsReplies: 7Last Post: 24th Jan 2009, 23:40 -
how many xvid can i put on 1 dvd
By peterg60 in forum Newbie / General discussionsReplies: 13Last Post: 19th Jan 2008, 06:56
