  1. This keeps happening when creating menus in Adobe Encore! When I create a menu in Adobe Photoshop and then convert text or other layers to buttons in Encore, the actual highlight section of the button (where the mouse turns to a hand) appears a centimetre or so above the actual button. Not only does this make it impossible to navigate but it also makes it impossible to create subpictures that actually work. This is driving me absolutely insane, can someone please help me!! I can't get my DVDs authored!! I spent money on this program and it wont even do what I bought it to do!!
  2. Here's an update....
    If I close Encore and open it again, the menu's work fine!
    Is there any way of refreshing the project while Encore is open?
    It is frustrating closing the program everytime I want to test a menu!
    Apr 2003
    Maryland
    I just mede a simple BG at 720 x 480 pixels and added a black text layer. Saved to PSD, imported as menu in Encore and converted the text to "button". Right clicked and choice preview from here and it work perfectly. Don't know what could be your problem. You could always create your text buttons ihn encore although it is limited in what you can do. PS is more versatile in text creation. Remember, that gradiants and some fancy text effects will not show up in encore when these are converted to button.
    No DVD can withstand the power of DVDShrink along with AnyDVD!
