  1. Hello
    I made many dvd using DVDAuthorGUI 0996b. Every dvd which has menu is broken. After menu played dvd player stops ,but menu should stay still. It doesn't matter if menu is 'still menu' or 'motion menu'.
    This effect doesn't exist when I play dvd on software player, but on standalone players exists.
    What can I change in settings to solve this problem?
    Best Regards
    ssobkows
  2. Free Flying Soul liquid217's Avatar
    Feb 2002
    Try increasing the frame count when you create the m2v still. Assuming you are a PAL user, estimate the number of frames by multiplying the number of seconds you need it to be tiles 25.
    Example: 10 seconds * 25fps = 250 frames
    Be sure to click the option to 'loop menu' if you are using a fairly long menu. (like a motion menu)
    Also, I highly recommend using 0.997, since there have been some bug fixes since 996b
