I compiled my project,when played in Power DVD everything is fine.
Put it in my standalone DVD player audio doesn't play.
I used mp2 file.Tried to convert to AC3 in ffmpegGUI but strange think happened after clicking Convert,nothing had been convert.Don't know why.
Anyway left it as mp2 but audio doesn't play.
Results 1 to 9 of 9
In ffmpeggui, always use the browse button, give your file a name that ends in .ac3 and then click OK, then Convert.
Cheers, Jim
My DVDLab Guides -
I did it in fffmegGUI many times but this time I set output file,input file,hit convert and I get a message righ away "finished"and file doesn't even exist.
Where did you get the original mp2 file?
I would load it into virtualdubmod, select streams, stream list. Right click the audio stream, select full processing, then Save .wav.
Load that .wav into ffmpeggui and transcode.Cheers, Jim
My DVDLab Guides -
agree with guns1inger -- could just be that your dvd player isn't playing the mpeg audio. is it an NTSC disc, or are you going through an amp?
George
How to make audio / video business card and website audio/videos clips
By tmh in forum Newbie / General discussionsReplies: 6Last Post: 4th May 2011, 11:25 -
Will Sony Vegas work with a high end audio interface used for digital audio
By fuzzblaster in forum AudioReplies: 3Last Post: 1st Sep 2010, 17:24 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 04:12 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 01:19
