Hello, I have been testing my PVR and attached is a sample pic of the quality of my Virtualdub resize using precise bilinear.
The left pic is the original capture 352x480, but i manually resized the player's window. The right pic is the capture (352x240) after I used the resize filter in virtual dub.
Notice the quality difference? Is it like this or am I missing something?
Thanks!
Any reason you are resizing?Of course you will get a crappier quality,i would keep the resolution at 352x480.
If you have to resize, skip bilinear. Either go w/ Lanczos3 or Hi Quality Bicubic (.75)
If this material is interlaced, I would highly recommend simply removing one field from the frame. Otherwise, if you use a bilinear resize, you will introduce field blending. Since you are using virtualdub, simply use the filter 'deinterlace' and 'discard field 1 or 2'. Then the final output will be 352x240 as you need it.
Converting 720x480 to 352x480
By Regor21 in forum Video ConversionReplies: 8Last Post: 9th Mar 2011, 11:34 -
How to patch 352x480 MPEG-2 to 720x480
By moxiecat in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 14:43 -
720x480 or 352x480 ?
By StoneColdWhat in forum Video ConversionReplies: 7Last Post: 7th Aug 2009, 09:16 -
VCD Aspect Problem. Header says 352x240 but WMP says 522x240!
By 201flyer in forum Authoring (VCD/SVCD)Replies: 8Last Post: 7th Jul 2009, 17:21 -
Please offer suggestions for 352x240 mpg...dvd is pixelated...
By AshleyQuick in forum Video ConversionReplies: 3Last Post: 29th Apr 2008, 01:13
