About a year ago I sold my analog Sony camcorder to get a nice new digital. Well, stupid me never copied my Hi8 tapes to any other medium, nor to the computer. So now without the camcorder I have no way of accessing these videos.
Is there any type of converter that would allow me to play these tapes in a VCR? I know I've seen something like that in the store where the smaller tape slides into a unit that looks like a VHS tape and the whole thing goes in the VCR.
Or do you have any other suggestions for transferring these videos to my computer or VHS?
Thanks!
Results 1 to 12 of 12
What kind of Sony camcorder did you get? The Sony Digital-8 camcorders can play 8mm tapes (if that's the kind of camcorder you happened to get)
George -
Unfortunately I ended up getting the Sharp VL-Z3. I say unfortunately because it won't play the Hi8 tapes but I actually love the camera.
I think those small tape to VCR converters are for a different type of camcorder tape. Could be wrong though.
Anyways, go to eBay and buy an old, used camcorder that plays the tapes. They're cheap - especially if you can find one that no longer functions properly as a camcorder but plays tapes fine. I bought on a while ago just to have a second one that is always hooked up to the TV (saves the hassle of hooking it up each time). Cheap - $20 or something. -
There is no adaptor that will play an 8mm tape in a VHS VCR. The adaptor you saw is only for VHS-C tapes. You need an 8mm/Digital 8 camcorder or player.
Unfortunately to play your old Hi-8 cassette you will need a Hi-8 VCR (very costly) or a Hi-8/Digital8 Camcorder. If you sold your old Hi-8 Cam to someone you know, then it might be possible for you to borrow it for some time.
But otherwise you have the following options:
- if the number of your Hi-8 cassettes is not very high, you could get them converted to DVD via some professional services
- you could buy a second hand Hi-8 Camcorder on eBay, do you job and then possibly sell off the unit again
Both are not very pretty options, but I am afraid that these are the only ones I can suggest. All the best.*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
Here's a Hi8 VCR. I bought the exact one here this weekend. You sure don't see many of them...Originally Posted by pbhalerao
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&rd=1&item=3875340608&ssPageName=STRK:MEWA:IT
*edit* Wow, just noticed it's still at $26... -
A steal at that price ($26 + $15 shipping)...
If possible, I would recommend a Sony Digital-8 camcorder that has the conversion with pass-through feature, and the ability to play 8mm tapes...
George -
Get one from rentacenter or a place like that, rent to own. Get one for like a week which should only cost you about 5-8 bucks or so, get the movies on your hardrive and then turn the camcorder back in. Brilliant!!
If you have a ton of disk space!Originally Posted by Nelson9937955
Wow, it blew up over the last day or so. Damn, I may sell mine...Originally Posted by pbhalerao
Converting old 8mm tapes to digital..help!
By MrMister007 in forum Capturing and VCRReplies: 7Last Post: 4th Aug 2011, 23:59 -
8mm tapes PAL with NTSC camcorder????
By igorv in forum Capturing and VCRReplies: 5Last Post: 11th Oct 2010, 14:17 -
archiving 8mm and dv tapes to recorder
By rikit in forum Newbie / General discussionsReplies: 7Last Post: 23rd Mar 2009, 18:05 -
Help with old 8mm camcorder tapes
By AmandaBMidlands in forum Portable VideoReplies: 2Last Post: 11th Nov 2008, 09:43 -
Advice on recovering old 8mm tapes
By VK4AKP in forum Capturing and VCRReplies: 4Last Post: 27th May 2008, 11:57
