Is there any way to take the motion menus from iDVD to use in another program (such as Studio 9?)
Depends - are they in a proprietry format, or just mpeg clips ? If you can get to the mpeg clips, then you may have to use photoshop to create new overlays. If they are in proprietry format then you are probably SOOL unless google turns up something.
Read my blog here.
Guide for extracting menus for editing, and reinserting edited menus
By manono in forum Authoring (DVD)Replies: 167Last Post: 8th Dec 2022, 02:44 -
IDVD themes
By greeneyes21 in forum MacReplies: 3Last Post: 21st Jan 2010, 20:05 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
Adding audio to dvd menus - Toast, iDVD, Other?
By Scav2003 in forum MacReplies: 6Last Post: 6th Apr 2008, 01:05 -
Magix Movie Edit Pro Menus and Sub-menus
By gayclarke in forum Authoring (DVD)Replies: 8Last Post: 11th Aug 2007, 10:07
