I can do it with a PNG Image just not with a TIFF Image.
Anyone know why? I know it dosent work with PSD Files, But the help File says it does with TIFF and PNG.
Results 1 to 9 of 9
I use DVD-A alot, but I don't know what it is you're trying to do. If it has to do with custom buttons or anything like that, I don't know b/c I use the stock graphics...
If you drag a PNG Image with an ALPHA on the menu it will show the transparency ,Just cant get it to with a TIFF Image.
I can do Custom set's to.Its just that this TIFF should work and I cant get it to.
Hmmm, sorry then, I can't help you. Maybe someone else will...
canadateck,Originally Posted by canadateck
First, if it works with PNG, why do you want to use TIF?
Second, TIFF format doesn't have Alpha channel transparency, PNG does.
Third, my DVDA 2.0b doesn't even allow me to insert TIFF image into the menu or use it as background image for the menu. It expects QT 6 movie with TIF extention.
Regards. -
Your Right.Originally Posted by kabanero
I just read that to use .Tif you must have QuickTime installed. But still no transparency , Not sure where I read it,Just looked through the help files and thats what I came up with.
Thanks for the help.
Problems with Alpha Channel
By CKyle in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2011, 17:02 -
Good compromised codec with alpha channel
By elmuz in forum EditingReplies: 6Last Post: 17th Sep 2010, 11:07 -
VP6a encoding / video with alpha channel
By GRUMBLE in forum Video ConversionReplies: 2Last Post: 26th Aug 2010, 05:08 -
where can i get 3D Clips with Alpha Channel for wedding or romanic scene
By DigitalGuard in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2007, 12:14 -
Video Clips with Alpha Channel
By MonaW in forum Newbie / General discussionsReplies: 1Last Post: 12th Jun 2007, 13:31
