I am tossing up between buying the ADVC300 and ADVC100. I have a few commercial tapes that are copy protected, and have read that the TBC in the Canopus units can remove macrovision. Is the TBC in this unit a full frame TBC? What would you guys recommend i buy as i will be converting alot of VHS tapes to DVD. Some commercial tapes and some home recorded and i want the best quality captures.
What are the main benefits for me to choose the 300 over the 100?
Thanks.
No.
But it may ignore it.Want my help? Ask here! (not via PM!)
The latest firmware upgrade for the advc300 removes macrovision , unofficially of course and once you've updated the firmware, you have to register on www.canopus.com to do this, follow this instruction: !
Hold the two adjustment button on the top of the unit. Not sure of the exact time length, but I think it is around 15 seconds. It worked for me. I hope it works out for you.
I think you have to do it each time you switch the unit on.
Good luckPAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Iv'e also read that this ADVC-300 only records the signal in DV...as i am not to familiar with DV, does this have to be converted to mpeg2 afterwards? or am i completely wrong and does the canopus capture in Mpeg2 or Avi.
I believe that the Canopus unit will capture the signal in AVI DV-Compliant format. You will have to convert it to MPEG2 later.Originally Posted by VEBouto*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
I have use Cyberlink power producer to capture in Mpeg format, there may be other software that will do that as well.
Does anyone here have the firmware and the updater software?
Edit: Found it. https://pro.grassvalley.jp/download/drivers/win2k/Last edited by digicube; 15th Nov 2017 at 18:23.
Canopus ADVC 300 DVD Capture Now?
By Detta in forum Capturing and VCRReplies: 7Last Post: 20th Sep 2011, 14:02 -
Capturing with canopus advc 300
By blacksheepdownunder in forum Newbie / General discussionsReplies: 1Last Post: 19th Jul 2010, 09:20 -
canopus advc 300 macbook pro
By petoo2 in forum Video ConversionReplies: 0Last Post: 9th Dec 2009, 20:29 -
Need help in choosing a VCR to be used with a Canopus ADVC-300
By teslaprofile in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2009, 23:31 -
Canopus ADVC 300: best settings / tweaks ?
By fabweb in forum Capturing and VCRReplies: 3Last Post: 12th Sep 2007, 07:34
