I have a new Pinnacle PCTV Studio Rave... and audio is fed out of the card into the sound card by an external audio cable.
My question... I am using VirtualDub - but when capturing the sound is taken from the 'MICROPHONE' not the 'LINE IN' which the TV Card sound is going into... (though the Preview window is fine)... how do I make VirtualDub use the 'Line In' not the 'Microphone' audio feed?
Thanks.
Open up the windows audio contols (double click the little speaker in the taskbar). Go to the advanced properties (under the menu) and select recording. Make sure your line-in is selected (check box under it ticked).
Voila
Mkvmergegui changing audio
By leon_pro in forum Newbie / General discussionsReplies: 4Last Post: 20th Apr 2012, 20:28 -
changing audio format
By spmint in forum Newbie / General discussionsReplies: 4Last Post: 3rd Feb 2012, 18:21 -
Audio sync issue, Virtualdub, old video clips changing frame rate
By litmus in forum Video ConversionReplies: 1Last Post: 19th Sep 2011, 12:35 -
Changing DVD audio
By 557953 in forum EditingReplies: 3Last Post: 29th Aug 2007, 09:14 -
Resizing AVI and changing bitrate using Virtualdub and XviD
By mlwitchking in forum EditingReplies: 7Last Post: 27th May 2007, 15:45
