MAME is a command-line program.
Not point-click Windowsware.
I believe WinKawaks may work for you (CPS, NeoGeo).
WinMAME I think is the other one.
Read some emulation sites.Want my help? Ask here! (not via PM!)
it looks like he has no ROMS -- of if he does, it should be "name "name of game" [options] in the command prompt -- as it shows clearly
hes trying to run the command line version.. there is a mame32 on the mame site.. jsut need to get that.. also he needs to point it to the proper dirs. IE rom art etc.. best get the mame32 exe first..
http://mameplus.emu-france.com/download/mameplus-0.92u2000-bin.exe thats a link to the mame plus versin . rev 092
still need roms..
The roms are in my roms folder. In my experience, the roms are opened from the emulator. That is what I'm having problems opening
I hope you left them zipped.Originally Posted by james636Want my help? Ask here! (not via PM!)
if you run that version of mame i posted.. put all roms in the rom dir..leave zipped then goto settigns and point the dirs to their proper places all will be fine.. if you run the audit all roms under the file hedder it will locate all working roms and non/broken roms for you also.
What is this sound card emulator?
By babypotato in forum AudioReplies: 2Last Post: 21st Jul 2011, 15:28 -
Will my pc run W7 32bit?
By neworldman in forum ComputerReplies: 6Last Post: 20th Oct 2010, 15:42 -
Looking for Freeware Disc Emulator
By Locut0s in forum MacReplies: 0Last Post: 3rd Jan 2010, 04:30 -
where is RUN on Windows 7?
By jyeh74 in forum ComputerReplies: 7Last Post: 17th Dec 2009, 19:00 -
XBox Emulator Available for Free
By videopoo in forum Authoring (Blu-ray)Replies: 0Last Post: 5th Mar 2008, 12:13
