When i selected the dvd mpeg2enc with this latest version 0.0.9s nothing happpens. the progress bar just twirls around. i have the mpeg encoder installed correctly as the list doesnt show at start up to tell if there is anything wrong. it worked on the previous verison even though the frames still froze as i've said.
With regard to the other post about the speed of the burning, i already tried a lower speed before but that didnt work either.
any ideas???
All i want to do is take over the world. Is that so wrong?
Do you mean the blue progress bar or the round indicator in the ffmpegX window? In the first case please post the process output by clicking the blue "i" info button.
The progress bar that i mean is the twirly stripy bar (technical description) that happens before any percentage bar starts. below is the info that i get and it dosent move any further after that. as ive said i was able to get it to work in the previous version even though the frames froze(please refer to my previous post).
Encoding started on Tue Feb 22 18:23:37 GMT 2005
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscalerAll i want to do is take over the world. Is that so wrong?
Try the option "Open in terminal window" and check if that gives more error information at runtime. You may also email me a clip or screenshots to major4@mac.com so as I may try to reproduce your issue and spot its source.
Problems Encoding DVD with mpeg2enc
By justin35 in forum ffmpegX general discussionReplies: 8Last Post: 11th Nov 2009, 15:07 -
Avi to DVD (mpeg2enc), doesn't fit screen (noob)
By bilboshaggins in forum ffmpegX general discussionReplies: 7Last Post: 14th Dec 2008, 15:53 -
mpeg2enc
By Corelogik in forum ffmpegX general discussionReplies: 2Last Post: 26th Oct 2008, 11:07 -
Crash in 0.0.9y converting AVI to DVD using mpeg2enc profile
By mainframer in forum ffmpegX general discussionReplies: 0Last Post: 20th May 2008, 02:05 -
Problems w/selectable subs avi-DVD w/mpeg2enc
By kenzo69 in forum ffmpegX general discussionReplies: 1Last Post: 20th May 2007, 06:53
