I have an .avi file with working audio, which I convered to a dvd compliant mpeg file. I looked it over in avi info and it says it has mpeg1 layer 2 audio. But when I play it with, windows media, mplayer, powerdvd it has no audio output whatsoever and my pcs audio card is working fine because other videos/mp3s play the audio fine so obviously it's the codec in avi info it suggested I go to a french site but you can't download the specific codec which I need it alows to download a codec pack but I don't want everything in that codec infact I only need the audio codec (I think). I searched this site for the codec because apparently ffdshow doesn't work for some reason but the only thing I could find was codec packs which I do not want. All I need as an mpeg1 layer 2 codec, aother note about mainconept, when I open the program it opens up ffdshow because in the task bar (bottem right) there are two ffdshow icons one is for audio and and the other for video how do I get ffdshow to work? I have already tried uninstalling and re-installing but it still does not want to work. Any help on this matter would be greatly appreciated.
But avi info and gspot both said there was audio in the converted mpeg file. I tried converting it about 4-5 times with and without ffdshow installed and once re-installed, and I still get a mpeg video file that shows it having audio according to gspot and avi info but the sound doesn't play when the video is played. Gspot and avi info both said there was a detected supported codec for running the type of audio even though it doesn't actually run. When I press the render button in gspot I get an error. I can longer produce this error because I delelted the bad file. BUt I don't want to convert again until I know it's going to work properly.
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Newer FFDSHOW versions screw up audio sync for me - why?
By TigerSoul in forum Software PlayingReplies: 7Last Post: 26th Mar 2010, 16:26 -
ffdshow audio filter config
By THX-UltraII in forum Software PlayingReplies: 0Last Post: 17th Feb 2009, 03:12 -
Audio codec problems after installing K-Lite and ffdshow
By iggie in forum AudioReplies: 6Last Post: 17th Dec 2008, 06:39 -
FFDshow audio decoder access violation
By silverwolf0 in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 14:05
