Could be power supply. I have had sudden reboots due to power supply.
Results 31 to 34 of 34
junkmalle,
You got it! I switched it back to pio on the secondary IDE cable, and it works just fine. I have already updated the drivers for the motherboard, any other ideas? -
Originally Posted by clvlndta3
DMA signaling is much faster than PIO so it's much more susceptible to noise and reflections. Here are some other things to check:
Make sure you have an 80 wire ribbon cable to the DVD recorder, not a 40 wire cable. 80 wire cables have much less crosstalk between conductors so you get better transmission.
If you have only one device on that cable make sure it's at the end of the cable not in the middle of a 3 connector cable. An open ended cable gets lots of reflections off the unterminated end. -
I have 2 devices on it, but I might only be running the 40 in instead of the 80. I'll have to try a new 80 cable and switch back to DMA and see if that makes a difference. Thanks for all the help.
Computer keeps rebooting again
By Illusionist in forum ComputerReplies: 5Last Post: 11th Apr 2011, 18:19 -
TMT3 is Rebooting My Computer
By wulf109 in forum ComputerReplies: 6Last Post: 21st Oct 2010, 12:09 -
randomly rebooting computer
By minidv2dvd in forum ComputerReplies: 0Last Post: 8th Sep 2008, 23:08 -
DVD burn...computer ID
By Tom81 in forum Authoring (DVD)Replies: 8Last Post: 27th Mar 2008, 08:25 -
My computer keeps rebooting before the logon screen.
By SE14man in forum ComputerReplies: 4Last Post: 8th Sep 2007, 14:21
