  1. for some reason my dvd rom drive does not recognize any media i put into it...cd/dvds that i have burned...purchased cd/dvds
    windows xp recognizes it as a drive that is working properly but i have no idea what is wrong with it...perhaps it's dead?
    i tried checking all cables to see if it's plugged in properly but no dice
    any ideas on what's going on or what i can do before i decide to trash this drive?
    thanks for any help
  2. Is it possible to try out the drive on a friend's computer?
    *** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
    Jul 2002
    Up in yo' bitch.
    thanks for any help
    Perhaps it is dead...
    Even though XP recognizes it as a valid drive there could still be some internal failure that is causing your problem (IE: Dirty laser... whatever). Your best bet is to swap it into another computer and see if you get the same results.
  4. well i took it out and i immediately heard something rattling...as if the lens was no longer connected...so i guess it's time for a new drive
