I was trying to back up one of my DVD's with DVD decrypter and it failing because of the structure protection on it. In settings of DVD Decrypter I set the structure protection to aggressive instead of normal but it still failed![]()
Is there a way to back up my DVD with DVD Decrypter or do I need to use different software?
I am posotive I am using the lastest version and I'm still getting the same problem.
Make sure you are using the latest version (3.5.2.0), if not download the latest one. People have had problems ripping dvds with structure protection on earliar versions of dvd decrypter.
Try using the default settings in Dvd Decrypter. When DVD decrypter fails, please state EXACTLY what error message you are getting. -
The Grudge is like the forgotten and other dvds with latest Arcos protection method.
Search this section with "the grudge".
Search is your underestimated friend
problem ripping BR lately..hardware? protection?
By carlos28355 in forum Blu-ray RippingReplies: 9Last Post: 27th Jun 2011, 01:17 -
Copy protection problem
By Kirsi in forum Capturing and VCRReplies: 2Last Post: 29th May 2011, 12:25 -
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
DVD Shrink structure problem
By janefield in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2010, 09:11 -
BD Rebuilder structure problem
By teicang in forum Blu-ray RippingReplies: 5Last Post: 3rd Aug 2009, 13:30
