I have a PAL MPG and i want to convert it to NTSC so i can make a DVD or VCD of it.
Can this be done and how can it be done.
Mark V
Results 1 to 14 of 14
Ok i am on 8 hours now and only 675mb is converted, is this supposed to be that slow?
I had a 700MB mpg.
Mark VMark V
10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D -
Why do i need DVD converter, my mpg is not on a DVD?
Mark V
Thank you, i will try that out.
Mark V
Originally Posted by Mark V
http://www.digigami.com/megapeg/index.phpWant my help? Ask here! (not via PM!)
mpeg2 works is great. I use DVD converter all the time for PAl to NTSC conversions. It does take awhile because your changing the frame rate which is not easy to do. Make sure all your other programs are closed and you select watch in terminal. This will help increase the speed but it does still take some time. Have fun!!!
Let's just make a CONSERVATIVE estimate that your time is worth 10.00 an hour. You can easily BUY a decent DVD player that will handle PAL DVD's, VCD's, and SVCD's for around 40.00 US. OR, you can spend hundreds of hours of your time trying to convert from PAL to NTSC, so you can have frame drops, skips and sync issues. My APEX 1225 cost me 39.99, and can handle any DVD, VCD or SVCD I throw at it. One less video conversion hassle solved. It's also easily hacked as an all region player.
Up to you.... 8) -
Nice info but i dont have a PAL DVD i have a PAL MPG.
What American model TV will play a PAL DVD? I dont know of any.
I also have a all region player.Mark V
Just burn the MPG as is to a DVD with Toast 6 or whatever. Then you'll have a PAL DVD.Originally Posted by Mark V
Most DVD players can output an understandable stream to a TV from either NTSC or PAL on the fly. I do this all the time and no transcending is necessary. The TV is not significant in this transaction, it depends on the DVD Player. The cheaper the better in my experience.Originally Posted by Mark V-laugh while you can monkey boy! - Dr. Lizardo -
None of my DVD players will do it. I have a new Toshiba DVD player, my PS2 with the Region X disc and a JVC DVD player that will not do this either.
That is how i found out it was a PAL MPG by burning it first and trying to play it.
Thanks for the help.Mark V
Then it's another issue entirely as to why it won't play. Also, a little more info as to what you're trying to do would be helpful. MPEGWorks does do good stuff, but I think ffmpegX blows it away in terms of ability to handle anything you throw at it. If you've got an all region player, use ffmpegX to convert your file to VCD, using the ffmpeg preset, and burn. It should work fine.
Thank you for the suggestion.
Mark V
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
PAL MPEG-2 to NTSC MPEG-2 - Different Color on TV
By HoosierGuy in forum Video ConversionReplies: 20Last Post: 5th Apr 2011, 13:43 -
random subtitles missing after remuxing converted PAL-to-Ntsc
By spiritgumm in forum SubtitleReplies: 5Last Post: 19th Jan 2009, 12:56 -
Fix ghost effect in a bad ntsc to pal converted original DVD
By Talayero in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:40 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 23:31
