  1. Member Conquest10's Avatar
    Chicago, IL
    How the hell do you import your old library and playlists into iTunes? Is there a way? I would really hate to have to recreate and reorganize all my playlists.
    His name was MackemX
  2. Member Conquest10's Avatar
    Chicago, IL
    Nevermind. Just restart iTunes and it imports everything intact.
  3. you can also look in the my music folder and just copy your old itl and xml files in there and it will load from those.
  4. Member Conquest10's Avatar
    Chicago, IL
    The problem is that I was doing that and it didn't work. I had to change the music folder in the preferences and it imported them once I restarted it.
  5. Originally Posted by Conquest10
    Yeah that would fix it.
