Chris,
Set up a project with 4 avi files (~ 45 - 50min each) and 1 small SVCD file (250MB). Before autofit was applied the predicted size was ~7.5GB.
Applied autofit and 2 pass and ran project. Output was 5.65GB.
Will run again tonight, what will you need from me if this happens again?
Aside from this, thanks for a great program.
Dwight
Results 1 to 10 of 10
Mmm, strange. At least your log file. Can you email it to me?
I'm running the process again right now. I'll see how it comes out this time and get back to you.
FYI: one of the log files for the project contains a lot of buffer underflows, causing the file to be 1.23MB in size.
Judging by the first file in this current run, the project looks like it will be oversized again.
Should I mail you the large log file or would it be easier if I send you a link for a download location? -
Chris,
Just updating the thread.
Tried RC5 on the same AVI's and came out undersized (3.5GB) with 'autofit' and '2 pass'.
I'm going back to RC3 and process 3 files, then follow up with DVD Shrink to get the last bit of tweaking for fit. -
Jikchung: I am still on the case... (thanks for the log file). Would you be willing to upload one of the avi's to my ftp for analsys?
Sure. Any preference which one (same one as before or a different one from that set)?
Same ftp as before? -
No need. I think i have it resolved. I will email you a test build tomorrow.
I can confirm the oversize/undersize bug is gone with RC6.
Thanks again Chris.
Oversize DVD's
By oldtimer33 in forum Authoring (DVD)Replies: 4Last Post: 15th Feb 2012, 08:29 -
VDubMod Oversize Files
By NeroLi8gerzid in forum Video ConversionReplies: 2Last Post: 6th Oct 2011, 06:16 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 00:16 -
BD-RB output oversize
By jchowland in forum Blu-ray RippingReplies: 4Last Post: 2nd Jan 2011, 09:29 -
StaxRip - oversize problem
By zacharias in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2010, 14:10
