Hi guys,
I author my own DVDs and would like to test my menus before burning. What is the best tool to test to see if my buttons line up right, and my menus go to the right places before I actually burn to a DVD? A free tool would be great.
Zakkkkkman
What do you use to Author them? You must be able to test with that. Heres some Players some free some not.
https://www.videohelp.com/tools?s=11#11 -
I do not know of a tool that does what you want, which does not mean that there isn't one. What works best for me is to burn my project to an RW and view it on the TV or whatever I intend to view it on. I know this seems time consuming but in the end you will always know exactly what your creation looks like.
I have re-used RWs many many times with no problems. Over time you will get a good feel for what works and what does not and you will not need to pre-burn an RW as often.bits -
Make an ISO, mount it with a virtual drive (e.g., Daemon Tools or Nero ImageDrive) and play on a software DVD player (e.g., WinDVD or PowerDVD).
Originally Posted by p_l
Windvd and powerdvd can play the vobs directly without a need for an iso mount. Just choose play dvd on harddrive or dvd on computer mode - terminology may be different. Then select the video_ts folder and it will load it exactly as if it were a physical disc, no iso needed.
Author to hard drive.
Open video files in PowerDVD.Want my help? Ask here! (not via PM!)
Burning VOB files to DVD WITHOUT Menus Or Chapters
By mediachimp in forum Authoring (DVD)Replies: 5Last Post: 11th Aug 2010, 01:11 -
[b][url]TEST! TEST TEST! WHAT"S THE BEST?!!!!!!!111111
By lordsmurf in forum TestReplies: 0Last Post: 2nd Aug 2010, 02:30 -
Burning a dvd so that it keeps the orignal menus/chapters..
By Dchristy47 in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2010, 02:11 -
mkv -> DVD with menus (ashampoo burning studio 9) not working.
By Substance001 in forum Video ConversionReplies: 3Last Post: 29th Sep 2009, 05:55 -
problem with menus when burning VIDEO_TS files to DVD
By samd292 in forum MacReplies: 3Last Post: 24th Jun 2008, 08:49
