i am trying to join two audio files with vitualdub, and it says that "the audio streams have different sampling rates". its not allowing me to join them. is there a way i can make the sampling rate the same? or some way to get around this problem?
You will have to resample one to match the other. If neither meet the final requirement (44.1khz for (S)VCD or 48khz for DVD) then you might as well resample both to the correct value before joining thus avoiding a second resampling later.
There are 10 kinds of people in this world. Those that understand binary... -
virtualdub.Originally Posted by dvdman24
Audio->Full processing mode
Audio->Conversion (select sampling rate reqd)
Audio->Compression (select None (PCM)
File->Save wav.
This will probably be quite a large file. Larger than the video if it is divx/xvid.There are 10 kinds of people in this world. Those that understand binary... -
I converted the file...and i got a wav file. Now what do I do with it? How do I join it back into the original avi? And then how do I join with the other file? The other file has to go through this process as well eh?
What you do now depends on what you finally want to do with it (covert to DVD or (S)VCD, make one big avi for PC playback etc...). Tell me that and I will tell you how I would handle it.
I'm gonna make a dvd out of it. One of the parts is only 50+min...so I wish to combine both to make full use of a single DVD-R.
Thanks bugster for agreeing to help!
Hope to finally solve this prob.
Edit: Just some extra info for ya.. I also use Tmpgenc to encode and Tmpgenc Author to author the dvd. Works great. -
In that case you can forget about all the hassle resampling audio in vdub or joining the avis in vdub. Simply encode each clip to mpeg spereatley, letting Tmpgenc resample each one to 48khz, calculate the video bitrate depending on the TOTAL playing time. Then import into TmpGenc DVD Author and tell it to play one clip after the other. (Don't ask me for exact settings to do this, I only know it can be done because I have seen many other TDA users suggest this!).Originally Posted by Immortal25There are 10 kinds of people in this world. Those that understand binary...
Audio Sampling Rate Info Wrong - DV-AVI Capture
By newtotheworld in forum Capturing and VCRReplies: 3Last Post: 21st Nov 2011, 22:18 -
The audio streams have different sampling rates, blah blah
By Kobong in forum EditingReplies: 5Last Post: 8th Jul 2008, 06:07 -
Issues with sampling/audio sampling/data rates and VdubMod
By Suprman37 in forum Video ConversionReplies: 4Last Post: 22nd Feb 2008, 01:09 -
Simplest way to join AVI files with diffferent Sampling rates.
By dagerousdave in forum Newbie / General discussionsReplies: 6Last Post: 15th Nov 2007, 07:03 -
how to rip audio from DVD and AVI without re-sampling
By ted demen in forum AudioReplies: 9Last Post: 23rd May 2007, 10:23
