Seems we lost the remote control for our old ( 10+ Years) JVC TV. I was wondering which remote we can buy to replace it. Does it matter?
Thanks!
"The name on the front of your shirt is more important than the name on the back"
Kurt Russell - Miracle -
Radioshack has lots of universal remotes I think. Doesn't really matter which one as long as it supports JVC tv's.
Hello,
Most remotes these days will work with any brand. Just be sure to get one with several programmable buttons. That way if you have a funky menu configuration you can assign it to a button instead of having just the keypad and volume, channel changer buttons....
And get a 5 or more in one job... Those are very convenient and can handle a lot.
I found one and it works great. Thanks for all your help!!
After some remote pc software..
By SE14man in forum ComputerReplies: 13Last Post: 2nd Aug 2011, 22:15 -
Which remote?
By Alomonger Pete in forum DVD & Blu-ray PlayersReplies: 4Last Post: 2nd Jan 2009, 08:13 -
remote codes?
By pamelajaye in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2008, 11:45 -
Remote
By WildParadise in forum Media Center PC / MediaCentersReplies: 14Last Post: 24th Apr 2008, 10:10 -
remote
By rtrg in forum Newbie / General discussionsReplies: 1Last Post: 1st Apr 2008, 13:46
