I have a strange situation. I took some avi files and used dvdSanta to make vob's from them. The output was about 5.8 gigs of info in VOBs. I then used tmpg dvd author to import the DVD files and make a menu. After I finished the menu I then clicked to save the output and it dropped my 5.3 gigs of vobs down to 4 gigs of VOBs (of course killing the quality).
I looked over EVERY option and I don't see how this occured.
Should I have taken my output from dvdSanta and compressed it with DVDshrink BEFORE using the tmpg dvd author?
I just dont' see why it would have compressed it WAY below what a standard single layer DVD's max can be. (I looked into the options and there are no size settings (and nothing in the help about compresion).
TmpGenc DVD Author does not include an encoder or transcoder for video, so it cannot have compressed the video. My only thought as to what might have happened is that you generated the vobs in DVDSanta with LPCM audio (uncompressed) and TDA converted this to mp2 or Ac3 (if you have the Ac3 plugin). This would explain the reduction in size. There will be no quality loss in the video and probabaly no noticeable quality loss in the audio.
The only caveat is that mp2 audio is not officially supported as part of the NTSC DVD specification. So if you are in NTSC land there is a small chance that your standalone will not play the audio.There are 10 kinds of people in this world. Those that understand binary... -
Interesting I saw no option on tmpg converting audio. Yes mine was left unconverted on dvdSanta the LPCM checked.
Will it always do that or is there a place I can force it not to do that and therefor yield more compatibility?
Or do you think I should let it do what its done and leave the less compatibilty for more on a disk with no video degridation?
TMPG DVD Author-old version
By Mållgan in forum Authoring (DVD)Replies: 12Last Post: 7th Mar 2010, 17:46 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 15:39 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 04:56 -
About the .srt subtle files and the TMPG DVD Author
By ihmcjacky in forum Authoring (DVD)Replies: 2Last Post: 10th Mar 2008, 11:58 -
tmpg dvd author 1.6 help plz
By nwa in forum Authoring (DVD)Replies: 8Last Post: 6th Jul 2007, 19:59
