Would someone gimme a full list of codecs i need please i heard huffyuv is quite good.
Just a long list of what you have and you're impressed with..
Only install codecs as you need them, what to install depends on your needs.
The huffy codec is a good codec for capturing from analog sources, it produces a high quality video with a fairly low file size compared to uncompressed AVI. Due to it's enormous size compared to MPEG it's only useful for making source files. -
ive had klite codec pack on here for ages now, would uninstalling it uninstall everything t do with it??
cheers bludclot -
No. And if it's not causing problems, I'd leave it in place or use something like codec sniper to remove things.
Read my blog here.
How come when watching a movie on my Dads pc with no codecs theres still lines on it only on mpg though..
maybe you have an interlaced MPG file. The monitor will display a progressive signal and you will often see lines in the picture when playing an interlaced signal on it. Every DVD I play in Power DVD looks like crap compared to on a television.
CODECs
By channelk in forum Capturing and VCRReplies: 5Last Post: 3rd Feb 2011, 21:34 -
what codecs do I need?
By johnsees in forum Newbie / General discussionsReplies: 19Last Post: 23rd Jul 2010, 08:53 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Please explain codecs to me: codecs within codecs?
By idsane in forum AudioReplies: 5Last Post: 2nd Sep 2008, 14:39 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52
