Hi
i replace a menu with an mpeg2 file.
now i want the file to play until its helf and stop....have the links display in that point and when the user make the selection i want it to play to its end.
how can it be done with dvd-lab?
S
reboot....i've read some of your guides...you are expert....so you might prove it again
It can be done with DVD Lab Pro, but not the standard version unless you want to use two clips. If you have the pro version, open the Help files (F1) and look at Motion Menus and Delayed Cells, both of which are under Menus in the index on the left.
Read my blog here.
Hi
I already did.
So I have 3 segments in the motion track when dragging the L mark and the most end bar which is the “Intro Cell 1” “loop cell 2” and “End cell 3” . I add a link as well.
In the real playback I see that the intro is playing till it meets the L mark than the loop cell section start to loop itself until I press the link.
When I prees the link the playback go back to the intro cell..than play the loop cell and than the end cell and go to the movie.
Why when I press the link it start to play all the video over again?
S
Program to control what others do on pc?
By t_jay17 in forum ComputerReplies: 8Last Post: 6th Apr 2010, 20:10 -
DirectShow: Precise control of video playback position.
By JCipriani in forum ProgrammingReplies: 4Last Post: 17th Nov 2008, 14:37 -
Selectable Output Control - MPAA's new control tactic
By akrako1 in forum Latest Video NewsReplies: 2Last Post: 7th Aug 2008, 22:05 -
How to Make Slideshow DVD with Slide Duration Control in the Playback?
By zeeman in forum Authoring (DVD)Replies: 6Last Post: 19th Jan 2008, 14:07 -
Copy Control CD
By ChiSholm in forum AudioReplies: 5Last Post: 11th Aug 2007, 11:18
