I have an iomagic 4x dvd r+ r- burner and I have noticed that with sony 8x and maxell 8x dvd+r they will only burn at 2.4x any ideas?? i have the latest firmware 2.60 and not sure where to go from here. I get same info from nero info tool and dvdinfopro. this is what they are telling me.
Media Information
Region information N/A not a DVD-VIDEO
Media code/Manufacturer ID SONY D11
Media Product Revision Number 00h
Free Blocks 405405696
Free Capacity 4.38GB(4.70GB)
Book Type DVD+R
Media Type DVD+R
Media Id Code Speed 8.0x 11080KBps
Available Write Descriptor CLV 1.0x 1385KBps
Available Write Descriptor CLV 2.4x 3324KBps
Data area starting sector 30000h
Linear Density 0.267um/bit
Track Density 0.74um/track
Number of Layers 1
this is what has me puzzled
I have no problems burning with most any 4x dvd even sony and maxell, just with 8x dvds
It seems your choices are to wait for a new firmware release that will enable 4x writing on the 8x discs you are having problems with, or return the discs where you bought them. Sorry.
Your burner likely simply doesn't recognize the Media code, so it's defaulting to the slowest burning speed, 2.4x.
Unless there's a firmware upgrade that includes these media codes, you'll be stuck at 2.4x with this media.
I just want to say thank you for the quick replies and i will give the iomagic support a chat in the morning if they answer
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 20:53 -
Trouble Authoring to DVD
By jmduke7 in forum ffmpegX general discussionReplies: 14Last Post: 14th Feb 2010, 08:52 -
Trouble with DVD Drives
By Cody_L in forum ComputerReplies: 3Last Post: 25th Dec 2008, 15:06 -
Trouble Backing-Up DVD...
By LCE in forum DVD RippingReplies: 7Last Post: 1st Nov 2007, 01:38 -
DVD playback trouble
By shorto in forum Newbie / General discussionsReplies: 3Last Post: 13th Aug 2007, 11:06
