I bought Memorex DVD+RW several months ago and I just started using them. I burned using TMPGenc DVD Author. All 3 of my DVD players would not recognize the disk. In my DVD drive, it would freeze the directory viewer, Windows Explorer, until I eject the disk. I know it burned correctly due to this layer of darker color on the back of the disk. What's wrong? I know for sure that my DVD players can play DVD-+RW.
Since the spindle contains about 50 of them, I have tried 2 of them and it doesn't work. Since I already opened the packaging and it was bought several months ago, I doubt I can return it.![]()
Try running an error check with Nero to see if there are any errors.
Sorry about the other topic, I was contemplating on posting later but I guess I clicked "Submit" on instinct! Please delete it.
How do I check for disk errors in Nero?
Memorex is 2nd quality, isn't that still pretty good?
I tried to do the Scandisk but even when I check "Surface Scan", the "Start" button is disabled.
I tried taking a disc from the middle of the spindle and burning again and again, nothing is on the disc after.
Is it possible that my DVD driver does not support DVD+RW discs? In Nero CD-DVD Speed, I get this message when I tried to click start:
Cannot simulate with this type of disc.
I have a Sony DW-U18A. Dual format up to 8X on DVD+R. And that's about all the information I know about it. -
Use this tool http://www.liteonit.com/ODD/Zip/BookType135.zip to change the BookType / BitSetting to DVD-ROM.
Also you may try the latest firmware: http://forum.rpc1.org/dl_firmware.php?download_id=1778 or http://dhc014.rpc1.org/indexOEM.htm#DW-U18A
Memorex DVD+R DL on sale
By GideonK in forum MediaReplies: 6Last Post: 9th Nov 2011, 19:38 -
Memorex DVD-R
By ozab in forum MediaReplies: 9Last Post: 15th Oct 2009, 18:37 -
Problems with Memorex Media. Where to buy Taiyo Yuden?
By John Shumate in forum MediaReplies: 11Last Post: 19th Dec 2007, 13:38 -
Memorex DVD-R $9.99 50pk at BJ's
By MrMoody in forum MediaReplies: 5Last Post: 13th Nov 2007, 02:31 -
Memorex DVD+R DL 8X Media Not Being Read
By Surfmaster in forum MacReplies: 10Last Post: 12th Nov 2007, 12:59
