I just created a DVD with subtitles. The problem is, when I playback on my DVD player the subtitles show only during certain scenes of the movie.
This is strange.
When I imported the subtitles all the correct text were there.
Results 1 to 18 of 18
I bet your subtitles crosses chapter boundaries. Or you added chapters that disected subtitles.
Illegal,
Brian-----------------------------------------------------
There is a reason why God gave us one mouth and two ears!!! -
Did you use dvd-lab or dvd-lab pro? Experts correct me if I am wrong, but dvd-lab does not support subtitles, dvd-lab pro does. Look here:
http://www.mediachance.com/dvdlab/comparison.html -
I just re-read your post and notice you already have some subs. Are these encoded onto the mpeg streams? and true sub-titles not showing up? Toggle subtitle button on dvd remote on/off and see if subs appear/disappear, or check mpeg streams for subs encoded to video(these can't be turned on/off). Otherwise I would go with awlchu's suggestion that they cross chapter boundaries, though I don't know why a chapter would be inserted in the middle of a sentence. Here is link to manual page for subs in dvd-lab pro;
http://www.mediachance.com/dvdlab/Helppro/index.htm
You can try to re-author the project without the chapters and see if that helps. Otherwise wait for dvd-lab expert like reboot to see this post and help out. -
I'm using the pro version, I have the SRT file.
I imported them, I did not merge them with the mpeg.
I added probably 2 chapters to the video.
I scrolled to the scene with the preveiw bar at the bodom right & clicked the + icon to add chapter. -
I have a similar problem.
I have chapters imported from dvddecrypter and 2 subtitle streams created by import the srt file from subrip.
All the movie works fine excepts the subtitles. They aren't shown on the screen never, as if subtitles are off.
I use DVD-Lab Pro 1.0 trial. -
I have recompile the dvd without chapter and have the same problem with subtitles
Could be the problem that have excesive subtitles? I have 1200 subtitles on the movie -
Which is the finally version.
i have 1.0
also, i did have multiple episodes on the disc, each episode i added subtitles -
Hey I was just curious... is there a way you can remove subtitles from a movie that is made with subtitles?
Well how do I know if its imbedded... cuase to be honest it doesn't look like it is.
@zero_net
Try to re-author with GUIforDVDauthor. I am using it everytime to author with srt subs and have no a single problem.
@hazeleyedoreo
If you cannot switch the subs off, they are embeded (part of the video frame) -
You can remove embedded subs, but only by masking and re-encoding.
Cheers, Jim
My DVDLab Guides
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 14:12 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 12:23 -
No audio and subtitles in DVD-lab PRO2
By 6ZIX in forum Authoring (DVD)Replies: 13Last Post: 11th Feb 2009, 08:14 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 15:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 15:57
