I am trying to rip a DVD to SVCD, and am having trouble setting things up properly. I am using DVD2AVI 1.76 to frameserve to TMPGEnc 2.0 Here are the stats from DVD2AVI when I preview the VOB files:
Aspect Ratio - 16:9
Framerate - 29.970
Video Type - FILM
Frame Type - Progressive
First, which template should I use in TMPGEnc, NTSC or NTSC Film? Second, what settings should I use on the Advanced page for aspect ratio, interlacing, etc, once I select a template?
I hope someone can help.
Thanks.
futhermore (at least for me) dvd2avi showed NTSC movies as having 23.976 fps too
Ok, two points.
1) 23.976fps vs 29.97fps. TV shows are shot at 29.97fps interlaced. Interlaced means that each frame is actually made of two fields (odd and even). Each has 1/2 the lines to be displayed. So another way to look at it is 60 fields/s. Movies are shot at 23.976fps progressive. Progressive in that each frame is a complete picture and they are shown one after the other.
In order to play a 23.976fps movie on your 29.97fps TV, we need to convert the film to that format. This is down by a process known as teleciding. Do a search on why, but basically if you have a telcided 29.97fps DVD rip, you'll want to convert it back to 23.976fps (a process known as inverse telecine aka IVTC), encode it, then re-telecine it (or add the 3:2 pulldown flag) so it can play on your TV.
IVTC will also generate a progessive source (ie. remove interlacing).
IVTC is very slow. So to save time most people just 'enable force film' in DVD2AVI to generate a 23.976fps output from the telecided source. If you're using TMPGenc then burn w/ the NTSC_film template to add the 3:2 pulldown flag.
2) Aspect ratios. First read :
http://www.doom9.org/aspectratios.htm
for some back ground. There are two seperate factors at work. The resolution of the MPEG and the DAR (display aspect ratio). You can have a DAR at ANY resolution (in theory).
Common DAR are 16:9 (movies) 4:3 (TV) and 1:1 (computer). The VCD standard calls for MPEG1 files at 352x240 and SVCD standard MPEG2 files at 480x480. Once you've 'locked/selected' that resolution you need to have your movie's DAR fit w/in it.
BUT WAIT! TV's are 4:3 ONLY. So you can't play a 1:1 or 16:9 source on them at a standard resolution w/o cutting off part of the screen or squshing the picture.
The answer. Letterbox/wide screen. We take a movie w/ a DAR of 16:9 and make it fit on a 4:3 display by adding black bars to the top and bottom.
With all that said thou, in TMPGenc you should be ok if you choose 425line 16:9 and full screen keep aspect ratio, and encode. Do a short test clip to be safe/sure (use source range)
Help with svcd 2 dvd
By tastybaker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 11th Aug 2010, 09:30 -
Svcd 2 dvd
By GeordieDave in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 8th Feb 2010, 10:05 -
Svcd Burning
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 16th Apr 2008, 08:25 -
How do I split a SVCD
By VoXiSo in forum EditingReplies: 1Last Post: 4th Feb 2008, 15:14 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
