I'm thinking of buying this PDA http://www.newegg.com/app/ViewProductDesc.asp?description=58-109-007&depa=0
What I want to do is then convert files to either QVGA or VGA for playback on the PDA. So what is the resolution for QVGA? I think VGA is 640x480. Also what programs will convert say AVI to mpeg at the required resolution? Thanks for any help.![]()
Results 1 to 11 of 11
I think It is 320x 240 , I really dont know much about it,I thought you could Play Xvid or Some kind of Mpg4 on those PDAs?
You can use MainConcept to encode to 320x240. -
Originally Posted by canadateck
Looks like a nice unit. However I bought the Compaq IPaq h6315. Has bluetooth, phone and GPS capability. I use Beyond TV to record to MPEG 2 via a PVR 250 and then convert at a time I specify to IPAQ High Standard (Half hour show takes 15 minutes to convert). I then drop the file onto a removeable 1GB Secure Digital card and plug it into the IPAQ. A 2 hour movie uses 64mb of space. So one can drop quite a bit of video on a 1GB card.
Along with MPEG and Divx. You could down load the MS Windows Encoder. It create into its base video format of WMV. It may still be limited to 320 x 240.
http://www.microsoft.com/downloads/details.aspx?FamilyID=5691ba02-e496-465a-bba9-b2f11...displaylang=en
Check the tools section here. There are some conversion program to do video to a Pocket PC.
Playing a video while wating in a long line is greate! Just remember to pick up an extra battry.
PS: QVGA is 320 x240. Note most of the pocket PC I have seen. The norma form of the screen is 240 x 320. or VGA 480 x 640. Even though the "screen" can be rotated in the later forms of Pocket PC.. Some program dont like the change. -
Thanks everyone. I believe what I need is a program that will convert a non protected DVD into the smallest file format that can then be played back via Windows Media Player 9.0 for the PDA. For example I would like to take a 100 minute DVD movie down to a file size of say 100MB for viewing on a PDA (if possible) via Windows Media Player 9.0. The whole process needs to be simple for me to figure it out.
Here is another solution...
https://www.videohelp.com/tools?tool=Pocket_DVD_Wizard -
Hi being doing this for some time now ,size for 320 by 240
I use flask with xvid 2 pass this work realy well. I run the video at about 120k and audio I convert to mono I end up with a file about 1meg per minCHEERS GARRY
Putting Together Movie Clips
By SeaBird in forum EditingReplies: 1Last Post: 24th Mar 2012, 11:31 -
Movie clips too fast - dvdflick
By Illusionist in forum Newbie / General discussionsReplies: 0Last Post: 23rd May 2010, 17:11 -
Capturing Movie clips
By Rockwall567 in forum Capturing and VCRReplies: 1Last Post: 30th May 2008, 21:20 -
Still have problem with .FLV movie clips
By misterbean in forum Newbie / General discussionsReplies: 3Last Post: 18th Mar 2008, 03:37 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 04:34
