Hi.I cant make svcd's play properly on my sony dvp s570d dvd player.i'm getting the svcd movies from my friend's ftp,so it's not me whois making them.Ok get to the point nowI'm using Memorex cd-rw's 700mb, it plays but some places choppes and stopes for 3seconds.I tryed Cursor's but no luck.Please can anyone tell me what is the problem or what kinde of cd-rw's should i use. Thank you
<font size=-1>[ This Message was edited by: matrixx on 2001-12-08 22:53:45 ]</font>
Do the SVCDs play well on a software DVD Player like PowerDVD or WinDVD? If no (still choppy), the MPEG stream is badly encoded
Plus when using MPEG2 VBR encoding, bitrate may not exceed 2600 kbit/s. If it does, the film gets choppy during the affected scenes. You can check the bitrate with tools like "Bitrate Viewer" (www.tecoltd.com)
<font size=-1>[ This Message was edited by: Headhunter3000 on 2001-12-28 15:42:24 ]</font>
Sony dvp-sr100
By deyangg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2011, 03:54 -
My Sony DVD player SONY DVP- NS718 H
By samyer in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2010, 23:56 -
Sony dvp sr-100
By munskin in forum DVD & Blu-ray PlayersReplies: 1Last Post: 19th Aug 2009, 11:04 -
Sony DVP-NS601HP ??
By jjfromm in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Dec 2008, 12:02 -
Sony DVP-NC85H
By jduffy in forum DVD & Blu-ray PlayersReplies: 1Last Post: 6th Jun 2007, 10:17
