I just had my basement flooded.A bunch of my vhs tapes got soaked.Should I pitch them? There is some historical footage I would like to recover if it is not too much trouble. Not deeply important. Dont really want to take the tapes apart.Any options?
GuestGuest
Research VHS data recovery on Google.
This is a specialized field but you can gather hints. -
Probably gently drying would be best.
I have got audio tapes wet and dried them.
The tapes a heat sensitive so you should dry then with minimal heat. (I. E. not a hair dryer or somehting like that.)snappy phrase
I don't know what you're talking about. -
I am no expert, but if there was sediment in the flooded water, it may cause problems. You might considter "gently" rinsing them in distilled water, then setting them let them air dry for a good 24 hours (mabey longer).
****Disclaimer****
Then again, I really do not know much about this sort of thing, so this is just a last resort Idea. Do not blame me if it does not work.
Comments welcom, sharp objects welcome, Flames... Not Welcome.Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think. -
I agree..... If memory serves me, cleaning tape or film they use a special chemical, but as edDV stated, i think it's pretty specialized area, espc. if there was any sediment..... but i may just be recalling things i have seen & read about film and not VHS tape, if just wet, i don't know.... never had that problemOriginally Posted by edDV
Man... sorry to hear it!!! hopefully it was not anything real important
Good luck & i hope you find out some info and save what you want to save!!!!!!!! -
I think I would go with Skiths idea. Rinse them in a LOT of distilled water to get all the debris out and let them dry in a low humidity atmosphere for about a week.
Try to play one. If it's a lost cause, well, you gave it a try. To go beyond that would require a disassembly of the cassettes and a cleaning of the tape from end to end or professional recovery. -
Did I tape over my DV tape??
By kginsbo in forum Capturing and VCRReplies: 2Last Post: 16th Mar 2011, 00:04 -
How can VHS tape color loss be possible? ("tape fade")
By lordsmurf in forum RestorationReplies: 31Last Post: 18th Oct 2010, 10:32 -
4:3 and 16:9 on the same tape
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 29th Mar 2009, 12:04 -
DV damaged tape ???
By cd090580 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 9th Dec 2007, 09:37 -
Used Tape Media
By NightFire in forum MediaReplies: 2Last Post: 16th May 2007, 22:01
