Hi , Im a newbie here.
I burned some VCD's using Nero, but I can't do much manipulation to the files, and the create a menu extra is kinda crappy.
Is there any other programs that are better than Nero for creating menus and burning VCDs?
tHANKS
Hi Juako,
Assuming that you already have the MPGs (compliant to VCD standards), VCDEasy is a good one to use. I find it can do good pictured menus.
There are bound to be plenty of guides on how to use it. There's a link to the left for "Guides".
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Hi,
To creating menus and burning VCDs, Photo2VCD is the BEST! It has a powerful menu designer, you can create menu templates with your own photos and pictures. What's more, there are Nearly 150 transition effects for you select.
Try it at http://www.photo2vcd.com . Good luck! -
Hi!
VCDEasy is outstanding as the best program for creating VCD with simple or complex menu structures.
It might look a little bit hard in the beginning, but there's great and detailed guides of how to use this very powerful program.
IMO no other program is as powerful as VCDEasy when you want to create VCD or SVCD
// Znooky
Error creating VCD
By maruz in forum ffmpegX general discussionReplies: 4Last Post: 17th Oct 2009, 07:42 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 17:51 -
Three programs and I still can't do what I want...
By ker-plop in forum MacReplies: 6Last Post: 13th Apr 2008, 01:57 -
Any Programs Do This?
By sj022698 in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2008, 18:39 -
Creating (S)VCD Stills with Audio
By Cornucopia in forum User guidesReplies: 8Last Post: 4th Aug 2007, 13:05
