Just found out,if you have previously set svcd2dvd to do a 2-pass encode adn saved the setting as default, then you decide on another project to only use one pass, svcd2dvd still proceeds to do 2-passes. Even if you save the 1-pass setting as default, exit the program and try again it still does 2-passes. I had to manually change the registry entry for AVI2PASS from True to False to get 1-pass encoding working.
Duly noted. Will get that fixed!SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Episode 6 Bug? Or Quicktime Player 7 bug?
By NY2LA in forum Video ConversionReplies: 3Last Post: 25th Jun 2012, 17:59 -
.avi file playback bug
By uruquiora in forum DVB / IPTVReplies: 1Last Post: 14th Oct 2011, 13:32 -
.VOB to .AVI Encoding Error Bug
By spinzore in forum ffmpegX general discussionReplies: 1Last Post: 27th Aug 2010, 02:51 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
2 Small-ish AVI -> 1 Larger AVI = HUGE File. Why?
By cxp36 in forum Newbie / General discussionsReplies: 2Last Post: 6th Mar 2008, 18:31
