after using svcd2dvd v 1.5 for a year or so i decided to give the new version a try and already struggling.
How to i convert my bin files to dvd.
in version 1.5 i loaded the bin files hit start and of it went, now in the new version i load the bin files into the assets window, then hit the author your dvd buttin and i get "no titlesets to author" so i try and load the bin file into the vts layout window and nothing happens.
any suggestions?
john
First click on Asset arrow at top of menu. Add you bin files. Next click on Asset arrow at the top of the menu. Click on (Extract mpegs from bin images).
When processing is done, click on Asset (Orange) next to bin files and you should see your mpegs. Click twice on your mpeg and drag it into the VTS Layout above it. Before creating dvd files you should go to settings and set them appropiately.
Next to Assets on top menu click on the disk and you'll be presented a menu for dvd creation
DVDSubEdit... Everything Is Wrong!!!
By Typhoon859 in forum SubtitleReplies: 18Last Post: 5th May 2009, 08:08 -
What did I do wrong???
By olofen in forum ffmpegX general discussionReplies: 1Last Post: 12th Jul 2008, 09:36 -
Where did it go wrong?
By video_enthusiast07 in forum Authoring (DVD)Replies: 1Last Post: 31st Dec 2007, 18:17 -
OK, what's gone wrong here?
By EddyH in forum Authoring (DVD)Replies: 6Last Post: 30th Jun 2007, 04:11
