Settings:
ffmpeg v 0.0.9s (with up to date binaries installed)
Source: XVid mpeg4
Target: DVD (ffmpeg)
Encoder: default MPEG2 [.mpg] ffmpeg
Subs: .sub file "Loaded" (also have .idx file not not sure what to do with this)
Video/Filter parameters: 720x360 DVD 16:9 w/ 60/60 custom letter box settings to convert 1:2.35 PAR
Problem: If I click "Preview" the mplayer icon pops up in the doc and immediately quits (no error message). If I click "Play", nothing happens.
Any suggestions so that I can actually preview the subs? Tried a search on this topic but all the hits I got were for previous versions of ffmpegX I did not see any reports of mplayer dying on launch.
Thanks in advance.
Correction, when I use mpeg2enc and select "decode with mplayer" then the preview button does work and subs do appear in the preview window. I see only kanji based subs (translating the English portion of the feed) however regardless of whether I load the .sub file or the .idx file. What I would like to see are English subs that show up to translate when the Japanese portion of the audio feed is running.
If there are multiple subs available in one of these files, is there any way to tell or is there any way to ensure that all will be selectable once the VIDEO_TS folder has been encoded?
TIA.
ffmpegX problem - Preview gives me wrong subs
By no-xplode in forum ffmpegX general discussionReplies: 3Last Post: 31st Aug 2010, 15:55 -
Video Preview problem in Vista
By barlowdog in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 15th Jan 2010, 04:14 -
Can i actualy preview the subs in the movie in DVD Lab ?
By mordor in forum SubtitleReplies: 0Last Post: 22nd Mar 2008, 10:02 -
video preview problem with submagic and stubtitle workshop
By ecc in forum SubtitleReplies: 0Last Post: 27th Jan 2008, 03:48 -
Problem When I Preview
By VaTo17LoKo in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2007, 07:36
