Hello,
I was looking to cut out the adverts from a DVB recording, and then burn to dvd. I've tried TMPGEnc but this seems to re-encode the whole of the file (taking 6 hours) and the quality seems far worse afterwards.
Idealy, I just want to select the advert and delete, but not knowing too much about the technical side, don't know how possible this is.
I apologise if this is a commonly asked question but I couldn't seem to find any help on the matter. And all the software I've looking for says it can cut etc.. mpg but doesn't say how as far as re-encodes.
TMPGE's DVD Author will let you cut an mpg2 file wihout re-encoding, you can even cut up an unencrypted dvd (i.e. vob files) without re-encoding.
Nyah Levi -
Thanks for the responses, I was using DVD author anyway, didn't realise it cut too, so thats the perfect solution.
Not perfect, At every cut you make there will be a very small pause when you playback it on a (standalone) DVD-player.Originally Posted by daint
(Someone suggested a fix for that, but it did not work for me.)
I am also cutting out commercials from DVB-S streams.
I first demux the DVB streams with Projectx and after that edit with Mpeg2schnitt. Works perfect for me and smooth playback at the cuts it makes.
Womble to edit out adverts - odd audio ?
By bahjan in forum EditingReplies: 5Last Post: 23rd Mar 2011, 13:25 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Cut adverts in .TS-files from Dreambox?
By nordic45 in forum EditingReplies: 3Last Post: 12th Nov 2009, 08:14 -
Cut parts out of a mpeg2 without having to re-encode?
By ltd. in forum EditingReplies: 7Last Post: 23rd Dec 2008, 17:21 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
