Hello .....
First off ..... I know if I spent more time searching I probably could have found my answer in here somewhere, but I couldnt find it exactly .... granted I only spent 15mins looking ..... Nonetheless this is what forums boards are for anyway .....
I have a new theater setup with a 130" projection screen, and I want to make a demo disc of all my favorite scenes from my DVDs. I want to do this so that when I demo my system I dont have to sort through 15 different DVDs to showcase the video scenes and audio scenes.
I would like to rip chapters from different disc and then make them all go on one DVD.
Ive used TMPGenc (or something like that) in the past to rip individual chapters but I dont know how to assemble different chapters back together to make one DVD.
Can anyone point me to a guide??
http://www.dvd-guides.com/content/view/46/59/
Put each chapter into it's own folder then assemble them back together with the same program...DVDShrink.
1) Take a whole chapter so the audio will not get messed up.
2) You do NOT need to Shrink just because the program's name is DVDShrink...but if you add too many chapters...you may need to shrink in the final process.
3) If you cannot or do not want the full chapter...that is a whole different ball game. I use Womble's MPEG VCR for stuff like that then re-author with TDA. -
Hello,
Actually one thing to add to hech54's post. You can choose just a portion of a chapter in dvdshrink. In reauthor mode go to the start/end button on the left side of the screen. From there you can select EITHER chapter or drag the little indicator tab for just the portion you want. It's not a step by step slider so you can't position it to the exact second but you can get very close with it.
thanks a bunch guys ..... Ill take whole chapters, I doubt ill fill the DVD up, because I dont want any compression on my Demo disc .....
did a quick little test .... works great .....
ive used shrink for years now, I never click the begin/end frames button before to see how to edit a title. Thanks a bunch...
Now I just gotta learn how to make my custom menu ....
Ripping Blu Ray Disc to DVD with same menu and chapters
By MI6 in forum Blu-ray RippingReplies: 2Last Post: 10th Sep 2011, 08:35 -
Creating a Blu-ray Theater Demo Disc w/ DTS-HD, TrueHD & LPCM
By scubasteve2365 in forum Authoring (Blu-ray)Replies: 6Last Post: 29th Jan 2011, 10:00 -
Need Guide for Bluray Disc Ripping and to Make AVI (Xvid) from Bluray After
By dabas in forum Newbie / General discussionsReplies: 1Last Post: 9th Aug 2010, 14:05 -
Ripping DVD Chapters
By wallywalters in forum Video ConversionReplies: 1Last Post: 9th Feb 2010, 12:58 -
Need to create a Blu-ray demo disc
By wiggin78 in forum Authoring (Blu-ray)Replies: 3Last Post: 17th Oct 2009, 12:35
