I'm currently using Cyberlink PowerProducer 2 Gold (comes w/ LG Burner). It does everything I want, including:
- DL DVD support
- DVD+/-VR support (create + import)
- AVI/WMV/MPG -> DVD
However, it is super slow! and re-encode every mpeg (no transcoding).
Are there any software that can do everything above + mpeg transcoding, and at a faster speed? Preferrably more templated menus?
NeoDVD 6.0? Its speed comparison chart is definately attractive...
Cyberlink PowerProducer 3? but I've read quite a few negative reviews here...
Thanks in advance~
Results 1 to 15 of 15
Just a note on the Ulead Trials -- they don't support Dolby Digital audio (although the non-trial DWS2.x and certain versions of MovieFactory 3.0 will decode/encode Dolby Digital -- the encoding is 2-channel only).
I only mentioned this because it looked like you might be importing discs from a standalone dvd recorder, and the dvd recorder might use Dolby Digital audioGeorge -
Try NeroVision Express 3. It is very restrictive in its menuing capabilities and I don't have speed comparisons but it's worth a try.
Regards, jrischregards, jrisch -
Do yourself a favor and learn to encode MPEG separately. Use authoring software ONLY for making menus.
Originally Posted by Baldrick
DVD Moviefactory... do u know about its speed? Does it support transcoding? Hum.. it has a low rating in Tool section here. -
Originally Posted by jrisch
http://www.mediostream.com/pdf/neoDVD_speed_comparison.pdf -
You need to learn more patience. Video is a hobby/job that requires time investment.
Wow... my own benchmark
test case: 20 min WMV -> DVD
Cyberlink PowerProducer 3 -> 17.5min
NeoDVD 6 -> 11min
I'd definately get NeoDVD if it can offer more features useful featuers found in PP3. -
Originally Posted by fanbanlo*** My computer can beat me at chess, but is no match when it comes to kick-boxing. ***
Carrying on to the above post, once the MPG (MP2) is ready, I use TMPG DVD Author to create the DVD. I have not had problems so far - though I could use some good templates (I am too lazy and tired to make my own).
*** My computer can beat me at chess, but is no match when it comes to kick-boxing. *** -
TMPGEnc 3.0 XPress + TMPGEnc DVD Author 1.6 = US$ 110.00
So expensive compare to all-in-one by NeoDVD or PowerProducer though...
TMPGEnc is not free for MPEG2... -
Fan, Nero 6 or Sonic DVDit are middle price all-in-one
solutions. If you are converting divx you may want to try either the film machine or DIKO which are free all-in-one apps.
For using separate steps, A good free mpeg2 encoder is AVIDemux. DVDAuthorGUI, GUI for DVDAuthor and DVDStyler, are good free DVDAuthoring software, and finally, CDBurnerXP Pro, and DeepBurner are good free burning software.
Hope this helps
RogThere are many ways to measure success. You just have to find your own yardstick.
DVD Authoring software needed for multiple videos and .sup subtitles
By EpiMann in forum Authoring (DVD)Replies: 2Last Post: 20th Apr 2011, 14:08 -
Suggestion needed from DVD to HD
By onlygk in forum Newbie / General discussionsReplies: 4Last Post: 20th Nov 2010, 05:44 -
Suggestion needed to select my capture device
By syedmahm in forum Capturing and VCRReplies: 18Last Post: 6th Sep 2010, 15:48 -
Suggestion for good software for previewing capture?
By The Kitchen Sink in forum Capturing and VCRReplies: 3Last Post: 26th Aug 2009, 09:26 -
New Job, Dont know dvd authoring but suggstions needed.
By Castor troy in forum Authoring (DVD)Replies: 32Last Post: 19th Jan 2009, 08:42
