I have recorded a musical performance and have about 15-20 video clips to make a DVD with. Is there a program that will allow me to make a menu like :
Using Nero Vision Express will only allow so many chapters per page and they also require a thumbnail. I don't need this wasted space. I need something simple and able to fit alot on the screen.Code:1. Tears of Joy 11. XXXXXXX 2. Opus 12. XXXXXXX 3. Romance 13. XXXXXXX 4. XXXXXXX 14. XXXXXXX 5. XXXXXXX 15. XXXXXXX 6. XXXXXXX 16. XXXXXXX 7. XXXXXXX 17. XXXXXXX 8. XXXXXXX 18. XXXXXXX 9. XXXXXXX 19. XXXXXXX 10. XXXXXXX 20. XXXXXXX
Thank you.
Results 1 to 9 of 9
44E
Ulead DVD Workshop 2 can do it. You can download the trial version for free. NOTE: the trial version does not support AC3 audio.
TMPGenc DVD Author easily creates text menus, just use the edit menu/create new menu option, its all there for you
I've just used a text menu recently for a DVD with loads of Pingu on it ...... for the kids of course -
If you wanted to continue with NeroVision you could consider making your own button. They are simple bitmapped pictures in png format using red for transparency and green for the image(which could presumably be shrunk). However you'd still be stuck with the standard layouts which have a max of 12 buttons.
Incidentally Nero have released another batch of templates and buttons for NVE. It is NVE3content.exe and downloadable from their site.
Regards, jrischregards, jrisch -
Very easy job with GUI for DVDauthor...
If your clips are already named as the intended button texts, GFD automatically uses this info to create the text buttons.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Yeah, that's an easy one. You may want to be careful though how much stuff you try to put on one screen (if you plan on viewing it on a TV).
WOW! You guys are great! Thanks for all the different ideas.
44E
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
HELP! Too Much Text - I Need Labelling Template For Text
By kasius in forum MediaReplies: 5Last Post: 6th Dec 2008, 16:08 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
Adding text over original text
By stixster in forum EditingReplies: 3Last Post: 17th Jun 2008, 05:14 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
