  1. If i purchase this program online from this website and it downloads on to my computer can i then bring it over to another computer if i put it on CD or something or will it only let me download for use with one computer?
  2. http://www.visiblelight.com/mall/productview.aspx?pid=7
    This is the website i was going to be purchasing from.
    Australia
    The only restriction is in the Licence Agreement ..
    1. GRANT OF LICENSE
    You may install and use one copy of the SOFTWARE PRODUCT on computer
    at your premises.
    You may also make one copy of the SOFTWARE PRODUCT for backup.
    There is no physical restriction on which PC you choose to install it.
  4. Member archaeo's Avatar
    Mar 2004
    mountains
    yes, what you download is a setup executable. Visible light also gives you the option to download 3 more times from their site (for version upgrades). You can just burn that exe onto a CD to store it.
  5. This is a good point. And it should make some folks think if they use a computer for video work that isn't connected to the internet. More and more, there is online validation and registration that may be a snag. Something to think about if you're buying software these days.
  6. Member rkr1958's Avatar
    Feb 2002
    Huntsville, AL, USA
    No on-line validation required. You just need the download, serial number and license key which are all provided to you by visiblelight after your purchase. Save the download and email (w/license and serial number) from visiblelight to CD after your purchase and install / use it on the computer of your choice.
  7. So if I put it on CD will i be able to install the download on to more than one computer?
  8. Member archaeo's Avatar
    Mar 2004
    mountains
    Only ONE installation at a time.
    1. GRANT OF LICENSE
    at your premises.
